Dusty Bradford
- May 24, 2001
Dusty the converter should be delivered on Monday.......yeah agree you originally spec'd the converter to be 3000 stall and its only 2600 @ 0psi anoth 400-500 rpm sounds good. Now thats going to make it looser up top correct? its already slipping at 14% or are there other adjustments that can be made to increase the stall and improve the slippage up top? Also as you say more rpm helps it couple well I think my engine is done around 5600 I dont think I can turn it much higher so this is where my concern is....if my rpms are 5600 at only 107mph which is what it did last week whats gonna happen if the slip% stays where it is and I turn up the wick.....at 117-120mph my rpms are gonna be through the roof if it will even pull that high? This is what the car ran with my old converter...11.7-11.5 @116-118
Everything is ok with your converter. We were looking for something that would cause more slip up top than normal but found nothing. If we raise stall you will most likely also see some extra slip depending on the shift rpm. If it was shifting early, holding the shift out longer can offset this slip. For example if we raise stall speed 400 rpm but you raise the shift point by 400 rpm you will have better spool without getting more slip. The other option for less than 10% slip without raising the shift point and still seeing 3000 stall is the 9.5 non lock.
