sabersaw30
- Apr 14, 2008
Did not want to spend the money on a prime tool wanted to make my own.Can I just break the handle off a screwdriver?I need some pics of homemade prime tools give me some ideas.
SignUp Now!Thats a good idea with the tube.I did the same but also welded a short piece tubing over the screwdriver flat to make sure it doesn't SLIP off.
We have a winner that is what I will do.All good ideas though.Grind off the end of a padal drill bit. Then tack an old socket over it so it won't slip off when priming. :biggrin:
Thats what I did! Just bought one through jegs and it works perfect! No grinding, No cutting screwdrivers, No welding sockets!!!My smallblock chevy primer works on mine.
I put a cam in and I want to make sure I got plenty of oil before I start tuning the motor over.Maybe this is a dumb quesiton, but can you prime the motor by just cranking it without plugs installed?
That's what I did too.I welded on an old socket in the end of mine to make a 'cap' works like a charm.
