who makes a trans brake set up for a GN 200-4r
Gbodyolds
need to know who makes a complete trans brake setup for a 200-4r and a part # if possible
your in queens and so are we .you need a brake,we make them.where in queens are you?we are in astoria long island city.
i had a car with a CK Performance trans in it i was very happy with it. how much do you get for a complete trans brake set up? i have herd some bad things avout other companys trans brake setups how does yours stack up to the competition?
a friend of mine sold an 86 cutlass to the guy as a roller he threw in a GN drive train and then my friend bought it back a few months later the guy said you guys did the tranny, shifter really nice, dont remember his name so what about that trans brake setup?
electric brake is 550.00.installation must be made with the transmission removed from the vehicle for it to work as it was designed.
Chris would you recommend using your trans brake with the stock drum?
I am going to have Jimmy's here in Mundelein IL do it and was not sure if I should fork up the extra $$$ for the drum also while it was out. The trans has already been beefed up except for the drum and shaft.
I eventually expect high 10's out of the car.
With a transbrake,I would definetly put in a stronger forward drum,I cant tell ou how many i broke on a 10 sec before buying one.
