who sells a kit rebuilding a stock turbo(1987)
any help would be appreciated.thanks in advance jim
I can get you anything youd need. Let me know the journal diameter and we can go from there.
thanks bison will let you know it's for a friend of mine will get in touch with you he is in the process of doing a rehab of hiss t-type can you pm me your number and i will pass it along to him i am acouple towns over from you and can swing by and drop it of for him.jim
I too am interested in obtaining a rebuild kit, I want to support forum vendors in this. I am in process of trying to obtain the correct spline measurements. I do know my compressor and output houting are A/R 60 by Precision. This is first time I've pulled the turbo off this or any of my past GN's, and this is not a stock turbo so I'm not sure what the size is at this time but will by this evening (if I can translate the micrometer readings to mm.). Thanks and I'm quite pumped to tackle this project.
By the way I'm open to any "pay attention to's" while I'm opening up this wonderful toy. So far I've just opened up the compressor shroud and exposed the fresh air splines.
