SignUp Now!i believe AC Delco has the wire adapter harness, and pretty much any 3.8 powered car built in the 90's has the mounting plate..
i got a coil packs, module and harness off of a series 2 in a 98 grand prix gtpIt was my understanding the correct module plugs right in and the incorrect one is just incorrect.
Are you saying the ones that don't fit can utilize wiring adapters?
Just for the record here. I been running type II ignition for some time. When installed I saw improvements across the board. Idle, cruise, lean cruise, spool up and wot all improved. I run 25 psi boost through gn1's past 6500rpm without skipping a beat.
RL
