Who wants to help me spend my $$$$
wb_7354
I currently have the original stock unopened 109 in my GN. 30k miles. I have the usual bolt ons. 6165dbb turbo. 9.5" ptc 3k stall. Xp fuel pump. Hotwired. Volt booster. Meth inj. TT 6.1 wb chip. PL. it's a great running car. I've been 7.20's 1/8 and 11.20's 1/4.
My goal is mid to lower 10's
I'm looking at doing Champion ported irons. Assembled With stainless valves. T&D shaft roller rockers. Etc. Ported Champion intake. Morel roller lifters. CompCams 206/206 or 210/210 roller. Cloyes double roller timing set. ARP head studs. All new ARP fasteners. (Cam, cover, intake, etc) obviously all new gaskets.
Should I step up to aluminum heads?
Which cam?
Any other comments or suggestions?
I'm planning on doing this ASAP. Does anyone want to quote me
$$? (PM me)
I plan on addressing the bottom end this winter.
Ported irons and 206 roller. What IC do you have? How much boost did it take for your 11.20s?
Why don't you just set that stock unopened numbers matching long block in the corner, and build a play motor to drop in.
That is an option I'm looking at.
I agree with the above. Build another motor. Good pistons, billet caps, cam and heads.
