Whose volt booster is this?
Squid4life
So I was going through some of my GN crap and found this. I actually thought I sold it a while back...
Anyhow, I ASSume it is an old school volt booster, possibly an ATR? Doesn't look like a Caspers, Quad Air, Kenne Bell, etc. Any ideas who made it, (if it is in fact a volt booster) and more importantly any idea how to hook it up? I would like to test it...
Any guidance is greatly appreciated!
James
the short black with the ring term mounts to one of the alternator case bolts
the red wire with the ring terminal goes to the charging post
the brown wire goes to the regulator plug on the alternator, you need both the brown wire and the stock wire in this plug.
the blue wire goes to the TPS signal, this is what triggers the unit.
the unit has adjustable voltage for normal driving, and WOT, those are the 2 hole plugs. The button is a 'test' button so you can set the WOT voltage.
Bob
Bob, I forgot to ask, what should the baseline settings be for each: normal and WOT? Or is it depending on the demands of the system/fuel pump?
the part throttle stuff doesn't matter much, 15 to 15.5 at WOT would be a good place to start.
B
