gunslinger
- Nov 21, 2005
I've been fighting a lean at WOT condition for a while now.
Fuel pressure wasn't rising 1:1 with boost, so I changed the pump, and that has been taken care of. Max fuel pressure on this run was about 65lb.
The O2 sensor was reading strange. When I'm just cruising down the highway, it's sticking between 530 and 560mv. It doesn't seem to be in good fuel control. I changed it, and it is a little better, but it's not switching like it should.
The only thing I'm seeing strange is the MAF reading. I thought it was supposed to lock at 255 @ WOT. Mine's not.
I had to ease into the throttle an pedal it once. You'll see that in the file. Damn street tires.
Combination is in my sig. Any suggestions would be helpful.
Thanks.
Thanks.
