If the gasket doesnt blow, then you'll blow a hole through the piston. The wrong pressure has to go somewhere.
Do you have direct scan Uffe? You may want to get better monitoring equipment and start relooking at everything. EGT's, IAT's, etc.. assuming there is no external issue with vacuum lines, MAF, sealing, etc..
It is common to oring the heads, becuase its easier. but I dont believe in that. If the head is lifting, then thats one issue..if the motor detonates or has bad/improper machining..thats another.
The pump has steel rollers inside it. Thats why the need for lubricant. dunno bout the low turnon..thats another issue..
Cars way faster than yours using stock head gaskets with tremendous success.
HTH
Julio
HTH
Julio
 before breaking more parts. Again..doesnt take much..simple stuff like a PCV, EGR line, MAF meter, etc..can cuase you to POP
