Why doesn't my Scanmaster read my wideband outputs?
"Turbo-T"
V6 on steroids
I just installed a powerlogger. I've been told when this is installed, the Scanmaster will show the wideband 02 if you want it to.
Mine doesn't. It only shows the narrow band millivolts.
I have everything hooked up, and on the powerlogger console it does display my wideband 02 millivolts in wideband form (10 rich, 20 lean) but not on the Scanmaster.
I even went in and told the program in the side tabs that I was running a PLX.
What do i need to do to make my Scanmaster display wideband 02 millivolts?
Click the scanmaster button on the config page (F3) in the powerlogger. A window will pop up. Check the box for wideband. ;)
