Why would i be using so much injector%
WoW, thats pretty interesting reading. My direct scan is saying 12.3 to 1. and yes translator w/ extender chip. and on hp the tci calculator is saying 479(forgot to see if at rear wheel or crank) thanks for your help guys. Im not so worried now. :smile:
I won't get too comfortable :) That hp range I gave was from kinda wide. If you are really at the low end of that range, like it appears you are, I'd go figure out why. You should probably be running faster than you are. Could be something as simple as the timing being off, or could be a mechanical issue like poor ring seal. I think there's more power to be had. I think the other suggestions made, such as getting a wide band O2 to do a better check of your a/f ratio, have a lot of merit.
John
I agree, but with a stock intercooler and 125k miles i cant complain too much. And about the rings sealing im sure theres a bunch because when im in alot of boost is leaks oil. Thanks for taking the time to help out.
