Dec 9, 2013 #1 1 1952ray Scrambled Dog Joined Aug 26, 2013 Messages 1,277 Installing the Wideband bung on the test pipe. Is this to far downstream. It's just easy to get to there
Dec 9, 2013 #2 Bescurred BOOSTED SHAMU v2.0 Joined Jun 10, 2001 Messages 1,580 My instructions said to put the bung 18 inches from the turbo
Dec 9, 2013 #3 B bad V6 Member Joined Oct 9, 2005 Messages 952 Mine is at the lower end of the downpipe, prior to the test pipe. Make certain it is placed in the 10-2 o'clock position.
Dec 9, 2013 #4 1 1952ray Scrambled Dog Joined Aug 26, 2013 Messages 1,277 bad V6 said: Mine is at the lower end of the downpipe, prior to the test pipe. Make certain it is placed in the 10-2 o'clock position. Click to expand... Thank you
Dec 9, 2013 #5 E earlbrown runs with scissors Joined May 26, 2001 Messages 7,541 Make sure the DP is sealed to the test pipe with something like a full weld or a band clamp. If there's an air leak at low pressures, you'll get a false reading showing leaner than actual.
