My car is doing some weird stuff,If I ease into the throttle and let the turbo spool on its own I get normal o2's,If I nail it and it kicks down and accelerates as fast as possible I get o2's in the low 700's and I also get about 3-4.5 degrees of retard.I have had a problem with knock and for some wierd reason it seemed to start when I put my rjc power plate in.I thought it might have been bad gass but I don't know.My blms are fine and I don't get knock betewwen gears.My fp is fine and boost is only at 15psi.Also when I start up cold my fuel pressure will be at 45 and by the time I run it a little and check it again it drops like 3-4psi by itself.If I let the car cool down it will go back to the original setting.I think I have a few gremlins loose in my car
