Will camaro brakes convert over?
sams86gn
Does anyone know if vacuum brakes from a 96 camaro will convert over to my 86 Gn? Will I need any additional parts or will the camaro have everything I need? Thanks in advance
Was it an LT1? The reason I ask it the rear discs convert over pretty easy. Not sure about the booster/master though, I just used one out of a monte carlo at the yard. I think for everything it was like $10
,Dan
It's actually a v6 car. So if the camaro won't convert over then I need to go to a junkyard and look for a monte Carlo or....??
What exactly off a Camaro are you looking for? 4 wheel disc brakes or just the power booster? The booster will only work on simular designed chasis so you'll need one off a G body for your car. The rear disc and front discs can be adapted to the G body platform but not the booster.
I was hoping everything would convert over...booster, pedal, and everything else that is needed to put vacuum brakes on my car. I guess I will be heading to the junkyard! Thanks
