will it bolt up
jadams
will a chevy turbo 350 bolt up in these car . if so is there anything crazy i have to do to make it work
thanks
jason
come on guy i need to get my car running again .i dont want to rip out the old trans out untill i find out if it will bolt up right
I believe u have 2 have a BOP case in order 2 even bolt up. Then you'd probably need a different crossmember mount and probably a different length driveshaft.
yea i know about the crossmember you just get one out of a v8 regal . and the driveshaft work . i just need to know it that bolt up . see my brother (crazygn) has a turbo 350 out of my old friebird . so it has to be a BOP case
thanks
jason
I believe the length on the th350 and the th2004r is the same the diffrence is where the trans mount is ..
Yes, same length trans.
