I had been told previously that I didn't have the correct tv cable, so I got a new one, but it took 14 clicks(out about 3/4 of an inch) to get it shifting right(using feel and the GM chart for a BR coded tranny, ie 1-2 14mph, 2-3 22mph, 3-4 43mph.....mine is now 1-2 14-15mph, 2-3 20-22mph, and 3-4 43-45mph at very light throttle). The tranny was bought from someone by Level 10 for me as the tranny I had sent them was the wrong one (they said no matter what they did, it was the wrong tranny and wouldn't last). The tranny they got me was supposed to be a correct tranny. They did a stage 3 rebuild. I can't remember what all was put in it, I'd like to say a 10-vane pump and a billet servo, to say the least. The servo does appear to be billet. I checked the tag, it says BY on it, underneath that is 8308-16-82. I checked some books and it seems that the tranny, atleast the case, is out of an 82-84 with a 4.1-4 in it. The valvebody, I noticed while draining the fluid, has BO8 or B08 stamped on it. I can't find any info on the valvebody stampings. Is the valvebody out of the same 82-84 with a 4.1? And the bigger question, will this tranny hold up? I have been told, by Level 10, among others, that unless you have a BRF tranny valvebody(BR3 I believe), which is the only difference with a TR tranny I was told, your tranny won't last. If you absolutely can't find a BRF tranny, then one out of a Monte SS will work, just not as good. The tranny seems fine, but I'd just like to know what I have and if I need to keep my eyes out for a BRF tranny. If there is that much of a difference, could I just find/buy a BRF(BR3) valvebody and put it in, (instead of a whole tranny) and then everything would be ok? I wonder about the "gotta have a BRF" since I just saw a 2004r for sale here that was in a 10second car or built for a 10sec car that has a TAF valvebody...or is that from an 86 TR or a reman'd unit that was deemed a replacement for the BR3? I really appreciate any input on this, thanks,
Priz
Priz
