B
boostbrother
Guest
Need help, my tranny will not shift under WOT. Transmission was recently rebuilt. It has an Art Carr 9 inch non-lockup, hardened forward drum and stator. If you leave it in overdrive it shifts early and acts like it is slipping. If you leave it in 3rd it will not shift until you let off the gas but it does not feel like it is slipping. I have adjusted the TV cable until my thumb is about to fall off. It does not change the shift point under WOT. It works great just cruising around. Need advice, please help.![Confused :confused: :confused:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png)
