Will these work?
gold69charger
I have heard that front GTA rims will work on a GN! Will the rear ones work if you have a spacer? and if so where do you get one?
Andris Specialties, I think is the name. They're about $160 and come in all sorts of widths, they're not a spacer, they're an adapter. ie, the adapter bolts to the hub, and then the wheel bolts to it. I've been using them for years without a problem.
www.wheeladapters.com has billet spacer/adapters
If you use the basic cheapo type spacer 1/4" or 5/16" is about the max size spacer you can use unless you get longer wheelstuds.
Re: Re: Will these work?
I would like to find out more about the adapters you are talking about. Anymore info. you could give would be great, I tried doing a search for Andris Specialties,but found nothing.
I checked and the difference between the front backspacing and the rears is 5/8. I think that would be too much for a spacer.
