May 5, 2011 #1 J jefffoxsr Member Joined Apr 18, 2005 Messages 61 Will this tire fit on stock rims and not rub the frame? BF Goodrich Drag Radial 275-50-15. Thanks.
May 7, 2011 #2 4 49-blues Active Member Joined May 30, 2001 Messages 7,628 depends which rim you re running-on a t type rims 3.75" bs no problem, gn rim 4.00" rear spacing might be tight.
May 8, 2011 #3 SCOOBY DOO BASED CANADIAN PATRIOT!! Joined Feb 18, 2007 Messages 3,944 jefffoxsr said: Will this tire fit on stock rims and not rub the frame? BF Goodrich Drag Radial 275-50-15. Thanks. Click to expand... If the BF GOODRICH sidewall measurement is the same as the MT DR...then yes it will fit with the stock GN rim...if your rear axle is centered.
