Will this work?
MauDeuce50
Need Rehab for Boost Addiction
Ok well i am having some various issues and discovered my turbo to MAF hose has a small hole in it. Since i need a new one i was just going to get an aluminum pipe to replace it since i already have a K&N cone filter. When I get the aluminum pipe can I just reuse the stock plastic elbow and have the filter where the airbox used to be? Does anyone know if that will fit?
What you can do is replace your stock flex tube with a aluminum tube and couple it to the MAP sensor then couple the cone filter to the other side of the MAP creating a custom type intake....just trying to help
