Re-tuning back to STOCK-BLM 154
V6Turbo
3" ATR Dual Exhaust, THDP, Walbro 255-Hot Wired, 9
Hi Folks, It's been a minute.
Had to remove my upgrades and get my GN back to stock (Turbo, IC, Fuel Regulator, new 02 NTK-Stock) to Pass Cali Smog-Referee; failing as gross polluter as well. Back to "Stock"
BLM is High
I've done as much to bypass potential vacuum/air leak.
1. Gasket on Vacuum Block completely eliminating vacuum throughout the line.
2. Bypassed the Turbo/Intercooler-Direct Pipe from Air Filter-MAF to Throttle Body
Chip: TT 50#, Emmision, ~38 PSI Fuel Pressure
but BLM still High-145 to 157. Any advise is appreciated.
EGR Valve is functional...holds under manual vacuum pump. However, pressing on the diaphragm doesn't seem to cause it to stumble, at least noticeably.
Thinking to adjust my MAF translator to "Rich" but would rather find the cause.
Other Scanmaster Reading:
INT 124 to 133
IAC 43
MAF
TPS.42
RPM 800
ATS 42
CC; Normal incrementing
Upgrades kept:
50# injector
LT1 3" MAF-Translator
Terry H. 3" Downpipe
Upgrades Bypassed; Alky Kit.
