blackairgn
- Jan 24, 2014
86 GN STOCK!!!!
I do not intend to RACE/TRACK
I just want better reliable parts, idle and boost.
Parts i have ordered but not insdtalled.
msd 8.8mm wires
walbro hpfp 255
Accufab fuel pressure regulator , 1:1 ratio what does the ratio means exactly?
racetronix hotwire kit
turbo tweak chip v5.7 burned for stock setup
my injectors are stock. 28lb right?
will my afpr let me adjust to 28 psi? or could i adjust it to 30 psi and my stock injectors handle it? also will i have problems with 30 psi with the tt chip even though its burned for 28 psi?
havent purchased any plugs yet. what kind should i get and what is the gap ? 35?
i have a scanmaster 2.1 but cant figure out why its not reading. comes on and i can cycle through the numbers about once and then it turns off. shouldn't it be on at all times? connections are good!!
msd 8.8mm wires
walbro hpfp 255
