Window washer
84GNTTYPE
Senior Member
I can't get my window squirter to work. I pulled the line after the pump to see if I got anything coming out, nothing. I pulled the line before the pump and cleaner that out, there was nothing in it though. Do I need to replace it or is there some way that I can test to see if it is working. I can't tell if it is humming, because the wiper motor works at the same time the squirter should.
Thanks for any help.
apply 12v to the motor,
you can get a spare at a junkyard for a few bucks if its bad
