Hi guys. Maybe I can get a comment on this issue.
I have a 9k mile 87 grand national I have owned for 4 years. 2 years ago I installed the following parts. hotwirekit, k&n filter, adjustable fuel pressure regulator 41 psi, acuator/boost controller set at 17psi, 160 thermostat, and TT chip customized for the mentioned fuel and boost. Car ran fantastic and was a night and day difference.
Then my issue started when I decided to remove cat and put test pipe in. It started to ping/knock at high rpm. I decided to remove my k&n filter and install stock airbox back in and that seemed to cure the issue in the warm summertime weather. I pulled the car back out after a few months and drove it with air temps at 34 degrees recently and she is back. My question to you guys is this. Could I possibly get by with just upgrading to a bigger fuel pump? Or will I have to go bigger fuel pump, injectors, and new tt chip as I have kinda researched on google. Like I said when I switched back to stock airbox in summer it cleaned her up but now with the cold air Im assuming I was probably walking the threshold anyway when I removed cat and am hoping I can just get by with a bigger fuel pump. Thanks for your time guys!
