Wiper motor plastic cover/circuit board from a TR
87 WE2
Looking for a wiper motor cover with circuit board from a turbo regal. I need one thats known good and has working delay function. I have one that only has high/low speed and would like to change it out.
If all else fails, it looks like Delco may still have that. May be p/n 22039684. Says "Windshield Wiper Motor Cover; w/circ bd; Pulse Wpr (CD4)". acdelco.com $84. Yikes... :eek: Looks like it was used on about 200 models between '84 and '88.
You will also need to also change the switch on the column from a two speed switch to a pulse type wiper switch. If you do not have a tilt column you will have to change over to a tilt column to get the correct switch to go with the pulse type cover on the wiper motor.
At least that is what I had to do with my GN with the two speed wipers and non tilt column to change over. Was worth it avoiding switching the wipers on and off, in the misty type rain showers.
By the way any pulse type cover from a mid 80 G-Body wiper motor will work on your wiper motor, it does not have to come from a turbo Regal
Thanks guys I have the correct swicth just need the motor cover with the correct circuit board.
Really do not want to pay $80 something for it, something off a parts car would work just fine as long as it works.
