Wire sleeves
T- Type Tim
Vice Chairman
What do you guys think about this stuff?
I want to remove as much of the plastic tubing and use this in is place
I used something really close to it or the same... you will need 1/8, 1/4, 1/2, 3/4 and 1-1/2 I believe. I think it looks clean, much nicer then what if was.
This stuff turned out nice.....used a lighter to keep the ends from fraying once cut. Plan to do my truck next
We use it on all the wiring we do...
You can also get wrap around shrink tape, should you not be able to get shrink tube over the connectors.
We use the hi Q shrink tube, w/ the adhesive in it. Won't slip off.
We use heat guns instead of lighters, so the chance of melting the nylon mesh is reduced.
We also use non adhesive tape to wrap some harnesses that are hidden.
If adhesive tape is needed, we use only 3M #33, & CUT it w/ a razor blade, so it's not stretched.;)
I’m going to check out the wrap around shrink tube
That would finish off the ends a lot nicer than tie wraps I think
