I have xfi w-caspers box. battery mounted in trunk. all conections are good as I can tell. on a hard launch I'm loosing power to ecu for a split second then the car continues the run fine. my battery is grounded directly to the frame then everything else grounds off of the frame. I'm going to run a dedicated ground to the ecu directly from battery. I would like to isolate the power and trigger for the caspers/xfi system to switches controlled by me and not the cars original wiring harness and column switches. Wich wires from factory haness need to be energized when the key turns on. I realize that the orange wire is power to the ecu from battery just need to know which others I need to manually trigger ie the same as key on.
