88 CuttyClassic
The Enviromental Hitman
- Oct 30, 2001
Here'e how i want to hook my two amps up. Run one 4 gauge wire a capcitor and then from the capcitor run one power wire to each amp. Will that work? I just don't wanna get that annoying headlight blink. the amps are both sony xplods, one is the 1000 watt sub amp and the other is a 760watt 2 channel. Will i fry the fuse alot if i wire two amps with one power cord? i think the fuse is 50 or 60 amps.
