wolfe bar and sway bar?
rtviper
When you run a wolfe bar can or should you have a sway bar also? I will see very limited street time but have noticed the car is a little unstable on the street with no sway bar front or back. It has the wolfe system only Thanks
When you say unstable , what tires are you running on the street ? I drive mine with the wolfe and no front bar, with Moroso springs and the car does not do any thing crazy or unstable. That is with 16 GNX wheels all around. I have driven the car to cruise night on slicks and you do have to be carefull.
Thanks Louie it may be the tires. I run the MT race tires up front on 3.5 inch welds and 10.5 inch MT slicks on the rear. Looking at the system it doesnt look like it gives much control of side to side movement like a sway bar would? I might be wrong thats why I asked It has the ajustable upper control arms and boxed lowers with the wolfe . I am going to try the new MT ET street Radial on the rear and the MT small street tire on the front.
