My buddies 87 GN with a TA-49 turbo, stock downpipe/cat/wastegate won't build more than 5 lbs of boost. Car runs fine (just slow), turbo sounds okay (no smoke,etc). What should we look at ?
Yep..did that. Even wired the gate closed with a coat hanger to
see if the actuator was messed up. Still only 5 lbs..Is it possible that convertor is plugged up and putting backpressure on the turbo to cause this ???
