BuickTurboSix
- May 25, 2001
I have a 85 Regal V8 that is giving me trouble. It won't idle. Dies out at the stop sign. Seems AOK if it is going down the road. And, once in a great while, idles ok for a period of time! At idle, if I put my hand over the carb, it will settle out. It is like there is a vacuum leak, but I sure can't find one. Pull the MCS plug and it will run fine too.
Here is what I have done. TPS was open, new one installed. New Air-Horn gasket. After the TPS was installed and the several days later, I put the OTC on it again and it showed a 13 and a 44. Cleared them and they have not come back, so I don't know if they are real or not.
In Mode 5, the MCS (mixture Control Solenoid) dwell goes from 4 to 45, but never sees the over 50 that all the manuals talk about. O2 sensor works. I see the output change when I do a load & choke test. But, I don't know if it is marginal in output. Reads .250 in lean condition and goes to 1.050 for rich.
Also, I don't know what to expect when I display Mode 4. What should the cross counts look like?
Getting the idea I am lost. What I don't get is - Is it screwed up because the O2 is reading lean and messing everything up, or is the O2 reading accurate for and indicating some other problem?? Any great ideas???? Very low mile car - 18,000. It's a sweetheart, but driving me crazzzzzzzzy! Help me fix this and I will surprise you with something in the mail!!! I don't want to break down and take it in!!!!
Thanks - Tom
Thanks - Tom
