Won't Start
Dan Thompson
I have not driven the car for maybe a month and it ran just fine then.
I removed my kill switch to the crank sensor.
When I turn the key I can hear the fuel pump run for a few seconds and fuel pressure is about 41#.
When I crank the engine it sounds like it will fire, but doesn't.
When I stop cranking the fuel pump runs for maybe five seconds and fuel pressure is about 50#.
I have the translator plus with the extender chip and I have checked the connectors and all seem correct. I also checked the orange wire behind the battery and its connected.
Not sure what to do next. Check my sig for the few mods I have, its mostly stock with stock injectors, some original.
Have you replaced your crank sensor yet? If not, you might consider that.
I'll look at when I can get under the car. Right now I don't have any room in the garage.
thanks for your input.
