I am having a problem leaning out in the top end at about 80 mph and over my o2 numbers just seem to drop to about 650 then it starts to knock so I let off.
Stock turbo, thdp, adjustable regulator, 50 lb injectors, turbo tweak chip for 50's 20 deg/18 deg. It started leaning out with this combo so I replaced the intank pump w/ a walbro 340, new fuel filter, and stainless lines because the line broke changing the fuel filter. I tried adding a little boost to a bout 17 lbs, lowering the boost all the way down to 14. Boost is holding constant with no creep in 3rd. Plugs are gapped properly at .035.
I also have been running the reccomended fp of 43 line off, I also have adjusted that up and down a few psi. I put a fuel pressure guage ran it to the hood and when the 02s are dropping the fuel pressure is staying constant at about 58-59 w/ line on. I also tried adding 20 % fuel w/ the turbo tweak chip but that didn't help.
Swapped out MAF meters, the Maf reads 255 with no drop out.
Battery voltage is staying constant at about 13.4-13.5 at Wot.
I am running out of ideas here. I am thinking about putting back in a set of stock injectors and another chip if I cannot figure this out...
any ideas appreciated.
thanks
thanks
