tonylukejr
- Aug 31, 2002
How much difference would it make to port and polish the stock heads with the set up I am running.
STOCK INTAKE
STOCK THROTLE BODY
STOCK REAR AXLE 3.42 GEARS
PTE FRONT MOUNT INTERCOOLER
HOT WIRE KIT
ADJUSTIBLE FUEL PRESSURE REGULATOR
STOCK CAM SHAFT
STOCK LIFTERS
STOCK PUSHRODS
STOCK VALVE SPRINGS,
STOCK DOUBLE ROLLER TIMING CHAIN SET HIGH VOLUME OIL PUMP
STOCK TIMING COVER
40-PSI INJECTORS
TE44C- TURBO with adjustable WASTEGATE
WALBRO 340 INTANK FUEL PUMP
3 INCH DOWN PIPE
HIGH FLOW CAT CONVERTER
3-INCH EXHAUST SYSTEM FRONT TO BACK WITH OPEN CUT OUT
2 FLOW MASTER TWO CHAMBER MUFFLERS
TRANSMISSION done by ART CARR trans has all EXTREME DUTY PARTS and can handle 850 hp.
CONVERTER IS 9 INCH 3600 STALL.
The CHIP IS THE ULTRA CHIP.
HYPERTECH 160-DEGREE STAT.
Tony
STOCK INTAKE
STOCK THROTLE BODY
HOT WIRE KIT
STOCK CAM SHAFT
STOCK LIFTERS
STOCK PUSHRODS
STOCK TIMING COVER
40-PSI INJECTORS
3 INCH DOWN PIPE
Tony
