Would like your opinion on a new exhaust cutout prototype.
I found a great article by a Turbo Systems Engineer from Garrett Turbos. It's long but very informative.Turbo Exhaust Theory
I stumbled across this information on a forum.
The following excerpts are from Jay Kavanaugh, a turbo systems engineer at Garret, responding to a thread on Impreza.net regarding exhaust design and exhaust theory:
“Howdy,
This thread was brought to my attention by a friend of mine in hopes of shedding some light on the issue of exhaust size selection for turbocharged vehicles. Most of the facts have been covered already. FWIW I'm an turbocharger development engineer for Garrett Engine Boosting Systems.
N/A cars: As most of you know, the design of turbo exhaust systems runs counter to exhaust design for n/a vehicles. N/A cars utilize exhaust velocity (not back pressure) in the collector to aid in scavenging other cylinders during the blow down process. It just so happens that to get the appropriate velocity, you have to squeeze down the diameter of the discharge of the collector (aka the exhaust), which also induces back pressure. The back pressure is an undesirable byproduct of the desire to have a certain degree of exhaust velocity. Go too big, and you lose velocity and its associated beneficial scavenging effect. Too small and the back pressure skyrockets, more than offsetting any gain made by scavenging. There is a happy medium here.
For turbo cars, you throw all that out the window. You want the exhaust velocity to be high upstream of the turbine (i.e. in the header). You'll notice that primaries of turbo headers are smaller diameter than those of an n/a car of two-thirds the horsepower. The idea is to get the exhaust velocity up quickly, to get the turbo spooling as early as possible. Here, getting the boost up early is a much more effective way to torque than playing with tuned primary lengths and scavenging. The scavenging effects are small compared to what you'd get if you just got boost sooner instead. You have a turbo; you want boost. Just don't go so small on the header's primary diameter that you choke off the high end.
Downstream of the turbine (aka the turbo back exhaust), you want the least back pressure possible. No ifs, and's, or buts. Stick a Hoover on the tailpipe if you can. The general rule of "larger is better" (to the point of diminishing returns) of turbo back exhausts is valid. Here, the idea is to minimize the pressure downstream of the turbine in order to make the most effective use of the pressure that is being generated upstream of the turbine. Remember, a turbine operates via a pressure ratio. For a given turbine inlet pressure, you will get the highest pressure ratio across the turbine when you have the lowest possible discharge pressure. This means the turbine is able to do the most amount of work possible (i.e. drive the compressor and make boost) with the available inlet pressure.
Again, less pressure downstream of the turbine is goodness. This approach minimizes the time-to-boost (maximizes boost response) and will improve engine VE throughout the rev range.
As for 2.5" vs. 3.0", the "best" turbo back exhaust depends on the amount of flow, or horsepower. At 250 hp, 2.5" is fine. Going to 3" at this power level won't get you much, if anything, other than a louder exhaust note. 300 hp and you're definitely sub optimal with 2.5". For 400-450 hp, even 3" is on the small side.”
"As for the geometry of the exhaust at the turbine discharge, the most optimal configuration would be a gradual increase in diameter from the turbine's exducer to the desired exhaust diameter-- via a straight conical diffuser of 7-12° included angle (to minimize flow separation and skin friction losses) mounted right at the turbine discharge. Many turbochargers found in diesels have this diffuser section cast right into the turbine housing. A hyperbolic increase in diameter (like a trumpet snorkus) is theoretically ideal but I've never seen one in use (and doubt it would be measurably superior to a straight diffuser). The waste gate flow would be via a completely divorced (separated from the main turbine discharge flow) dump tube. Due the realities of packaging, cost, and emissions compliance this config is rarely possible on street cars. You will, however, see this type of layout on dedicated race vehicles.
A large "bell mouth" config which combines the turbine discharge and wastegate flow (without a divider between the two) is certainly better than the compromised stock routing, but not as effective as the above.
If an integrated exhaust (non-divorced waste gate flow) is required, keep the waste gate flow separate from the main turbine discharge flow for ~12-18" before reintroducing it. This will minimize the impact on turbine efficiency-- the introduction of the waste gate flow disrupts the flow field of the main turbine discharge flow.
Necking the exhaust down to a sub optimal diameter is never a good idea, but if it is necessary, doing it further downstream is better than doing it close to the turbine discharge since it will minimize the exhaust's contribution to back pressure. Better yet: don't neck down the exhaust at all.
Also, the temperature of the exhaust coming out of a cat is higher than the inlet temperature, due to the exothermic oxidation of unburned hydrocarbons in the cat. So the total heat loss (and density increase) of the gases as it travels down the exhaust is not as prominent as it seems.
Another thing to keep in mind is that cylinder scavenging takes place where the flows from separate cylinders merge (i.e. in the collector). There is no such thing as cylinder scavenging downstream of the turbine, and hence, no reason to desire high exhaust velocity here. You will only introduce unwanted back pressure.
Other things you can do (in addition to choosing an appropriate diameter) to minimize exhaust back pressure in a turbo back exhaust are: avoid crush-bent tubes (use mandrel bends); avoid tight-radius turns (keep it as straight as possible); avoid step changes in diameter; avoid "cheated" radii (cuts that are non-perpendicular); use a high flow cat; use a straight-thru perforated core muffler... etc.”
"Comparing the two bell mouth designs, I've never seen either one so I can only speculate. But based on your description, and assuming neither of them have a divider wall/tongue between the turbine discharge and wg dump, I'd venture that you'd be hard pressed to measure a difference between the two. The more gradual taper intuitively appears more desirable, but it's likely that it's beyond the point of diminishing returns. Either one sounds like it will improve the waste gate's discharge coefficient over the stock config, which will constitute the single biggest difference. This will allow more control over boost creep. Neither is as optimal as the divorced waste gate flow arrangement, however.
There's more to it, though-- if a larger bell mouth is excessively large right at the turbine discharge (a large step diameter increase), there will be an unrecoverable dump loss that will contribute to back pressure. This is why a gradual increase in diameter, like the conical diffuser mentioned earlier, is desirable at the turbine discharge.
As for primary lengths on turbo headers, it is advantageous to use equal-length primaries to time the arrival of the pulses at the turbine equally and to keep cylinder reversion balanced across all cylinders. This will improve boost response and the engine's VE. Equal-length is often difficult to achieve due to tight packaging, fabrication difficulty, and the desire to have runners of the shortest possible length.”
"Here's a worked example (simplified) of how larger exhausts help turbo cars:
Say you have a turbo operating at a turbine pressure ratio (aka expansion ratio) of 1.8:1. You have a small turbo back exhaust that contributes, say, 10 psig back pressure at the turbine discharge at red line. The total back pressure seen by the engine (upstream of the turbine) in this case is:
(14.5 +10)*1.8 = 44.1 psia = 29.6 psig total back pressure
o here, the turbine contributed 19.6 psig of back pressure to the total.
Now you slap on a proper low-back pressure, big turbo back exhaust. Same turbo, same boost, etc. You measure 3 psig back pressure at the turbine discharge. In this case the engine sees just 17 psig total back pressure! And the turbine's contribution to the total back pressure is reduced to 14 psig (note: this is 5.6 psig lower than its contribution in the "small turboback" case).
So in the end, the engine saw a reduction in back pressure of 12.6 psig when you swapped turbo backs in this example. This reduction in back pressure is where all the engine's VE gains come from.
This is why larger exhausts make such big gains on nearly all stock turbo cars-- the turbine compounds the downstream back pressure via its expansion ratio. This is also why bigger turbos make more power at a given boost level-- they improve engine VE by operating at lower turbine expansion ratios for a given boost level.
As you can see, the back pressure penalty of running a too-small exhaust (like 2.5" for 350 hp) will vary depending on the match. At a given power level, a smaller turbo will generally be operating at a higher turbine pressure ratio and so will actually make the engine more sensitive to the back pressure downstream of the turbine than a larger turbine/turbo would.
Take all of this and set it aside ...
A single 3" exhaust with a single muffler and a simple 2.5" dump .. has gone bottom 10's ..
I am not even sure how many TR have been run within a few hundreths "OPEN" or "CLOSED" exhaust ..
The better quality exhausts are very very free flowing and you gain nothing by running a open pipe .. except of course the noise and cool whistle factor :)
I had to stop reading that redundant tale from the expert after the fifth ''back pressure'' reference. He should have thrown in a few dozen ''you know what I'm sayin?" at the end of sentences.
I know it might be alittle off topic but, A bolt in CAT for the TR with a exhaust cutout built in to the case would be a nice piece. It would be marketed more toward the weekend warrior guys in those states that care too much about the atmosphere. Just have a bypass built into the inlet side with the standard dump fabbed on the side.Just a random thought from someone with nothing better to do at work.
Great and well thought out design. My GN is lowered, so I like the low profile. I love the curve and whole concept... but... is there any way to make it electric open/close ?? I currently have the classic y pipe with electric open/close switch... I love the sound and open it up often. =)
We don't have an electric one available yet. We thought we would start off with the manual design. I had one of the 1st guillotine style cutouts that I purchased from the original vendor before Dougs Headers took them over years ago. Love the electric ability, just not the issues. I'm glad your not having them. Not everyone does. I'm curious, with your mods, could you drive around with the cutout open without offending everyone, if you kept your foot out of it?
