WOW!! New High Torque Mini Starter with bolts $95 shipped!!!
bigal614
Supporting Vendor
WOW!! New High Torque Mini Starter with bolts $95 SHIPPED!!! :eek:
High Torque, Gear Reduction Mini Starter fits GM engines. With a 4.4 to 1 gear reduction it provides 50% more torque than stock starters and weighs less than 8.5 pounds. Fits 153 tooth flywheel only. Includes the proper shouldered starter bolts
The kit supplies everything you need to change out your 18.5lb clunker (stock starter) with this new 8.5lb beauty. This starter is brand new!!!
•Direct Bolt in. Hooks up exactly as the old style starter
•10lbs. weight savings! This starter only weighs 8.5lbs!
•Brand New.
•Smaller configuration positions starter farther away from header and downpipe
•Complete Kit, with new special GM starter bolts. (Stock GN Starter Bolts will not fit)
*Full 1 year limited warranty
*I can send pic on request if you don't believe the Krazy deal that I'm offerering?!?!?
Buy now while I still have some at this price because it won't be going any lower!!!
(PS.) I'm sorry but there will be a $5 Shipping charge West of Texas due to the rising cost of fuel.
Thank you in advance
bigal6142
