SignUp Now!Will it make more power with the cooler plug?
I was curious what effect the cooler plugs, has on the engine at 25#boost.
i am surprised that the plugs arent getting blown out with that gap. i run .030 on a autolite 23 or an ngk ur5's
no i meant the spark getting blown out but wow yours is a new oneDo you mean physically blown out of the head? I had an autolite plug do that and I thought the plug was defective. If I remember correctly, threaded part stayed in the head and porcelain part broke, leaving the plug wire just dangling. Can't remember the gap but was probably around .032. I was accelerating when it happened but the pedal was not floored. I checked the other plugs and the porcelain was cracked on another one. I quit using Ford plugs after that.
