I have one that was cut off at the third break light. You would have to extend it with a piece of wire. To do it correctly you should run a wire up to the brake switch and swap it out for the 86/86 style if possible. If you just tap the wire in the trunk, the third brake light will flash with turnsignals..... ask me how I found this out
