WTB: Built short block good for 9's
Still thinking of a LSx?I did a local search for 4.1 in our area and have a few guys getting back to me if I locate one you want me to hold one for you?
Rick what happened to your motor?????????? Are any of your internals still good to use in a rebuild?
John, I think I'm going to fix it. Thanks for lookin out.
Nick, I need a block. Internals "so far" are salvageable. I lost oil pressure. Took out the bearings. Some metal in the pan has yet to be identified and found a crack in the block when I pulled #2 main. O-ya, to top it off, I got a speeding ticket today.
I need a xanax.
Fresh RPE 6109 block rebuilt with billet mains, new roller cam,new front cover, new water pump, roller timing chain, new deep rjc oil pan,arp bolts and studs throughout, SS front cover bolts, new diamond .020 forged pistons-$5300. shopped in the USA.
No steel crank?
I was planning a steel crank/rods on next build-bobbie said i didnt need them for low tens-so i went with his recommendation-i already had $4200. into the build and assembly which i thought was a good idea cause i have a stage 2 block i would like to build.
I'll pass on that. Thanks.
