SignUp Now!Ok ill ask why cant you do 700whp on a 64?Hi
I am about to swap out my 64/66 for a HPT 68/70 for my 4.1 stroker, looking for atleast 700rwhp, is it a goog shoice?
Making 590 rwhp today.
Dont now it will only spool to 25 psi.Ok ill ask why cant you do 700whp on a 64?
Havent check the backpressure no sensorWhere is your backpressure now?
Exhaust leaks can spring up at any time..ask me how i know : / 26 is about where mine stopped with a JB6766är på
ExternalWhat are you using for a wastegate ...internal or external ?
Need to look at it to see where the system is at.Havent check the backpressure no sensor
The first thing that comes to mind is that exhaust pressure is forcing the wastegate puck open. You should be able to find a spring at the local hardware store to increase the pressure forcing your puck closed. Drill a hole in your actuator bracket to attach one end of the spring to then remove the clip on the swing arm and install the other end of the spring in its place.är på
He's on an external gate , but we don't know if he's using manifold pressure ( I think he is ) or CO2 .The first thing that comes to mind is that exhaust pressure is forcing the wastegate puck open.
I read external, but my brain turned it into internal.He's on an external gate , but we don't know if he's using manifold pressure ( I think he is ) or CO2 .
100% Running co2 has been much more consistent than boost to hold the gate shut.Im going to do an internet guess and say get need needs some co2 and dome pressure![]()
