WTB: Ported iron heads or aluminum heads
Steve
I am looking for a set of ported iron heads or possibly aluminum heads. I would prefer some that are fresh and ready to go but I will consider any good ported heads. I will be running a roller cam so ones set up for a roller would be a plus but I can make the needed changes if they are set up for a flat tappet. Thanks
i have some fresh ported heads bare i also have some brand new ferrea oversized valves i bought still new in box to put them on heads also have some roller rockers i bought still new in box to match the setup if intrested pls text me or call me @ 786 487 3024 i have pix on my phone im not on my computer right now im currently in process of moving but i have tons of pictures on my cell... i'll give you a good deal package deal thanks,
I can port a set for you. $750-$2500 depending on options and modifications. Good flowing heads with stock (modified valves) are $750, and go up from there. Bigger valves 1.77" to 1.84", deck pinning to hold the gasket better and support the weak deck on the intake side, head bolt and push rod tubes for the folks that want a full on iron head. 90% of the gain is in a standard port job with stock valves. The last 10% is a dog fight.:) PM if you have questions.
