Wtb: Turbo saver or turbo luber
Turbo Luber? Do you mean something that pumps oil through the turbo before it starts and post lubricates the turbo while it spins down and cools down? Or just a filter set-up?
Hope this helps you.
Turbo Oil Protector Kit
We sell these if you want a new setup. Simple and works. TURBO PROTECTOR KIT
Hey Mark,
Looks great! I'm very interested in your Turbo Oil Protector Kit.....I see that your info states the housing is 6 1/4" Long x 3 1/4" dia.
Presently using RJC's Biggie oil filter adapter and #M1-203 Mobile 1 Oil filter which is 4.4" long x 3.66" dia. I'm running a PTE SLIC and not sure if I've got enough clearance at the side bracket for this set up? Unfortunately car is in winter storeage (about an hours drive away), so I can't run out to the garage to double check. However found a couple of pics I had on file and doesn't look too promising for me. Have you had any experience of feedback from other turbo buick owners running your set up with Precisions Stock Location Intercooler?
Can you verify the actual dimensions are correct?
Here's a picture I had on file.
Maybe if I trim the aluminum intercooler support bracket ...the reduced diameter of your unit...just may fit?
Your thoughts please.
thanks,
dave
Actually, just had a customer with this same issue and did a setup with same type of filter with a 4.25 long body. Same price as the one on the site, just remind me you want the shorter one for use with the PTE SLIC and will take care of it for you.
