98 Pontiac trans am
100330 miles
Ls1 stock bottom end except arp rod bolts rebuilt around 98k miles
Diamond pistons 12.1 compression
Hardend pushrods
fast 90 intake
nick williams tb
Taylor wires
Tr6 plugs
Patriot perf ls6 heads
Long tube headers
Polyurethane engine mounts
Comp cam
23x
23x
60x
61x
112 lsa
Nitro daves wet-kit(capable of a 250 shot)
Nitro daves bottle mount(mount between rear seat)
6-speed
b&m ripper shifter
hardend syncros
new 2nd and 3rd gear
spec 3+ clutch
2002 hydraulics
drill mod
adj. master cylinder
Polyurethane trans. Mount
Also have the original t56 6-speed w/ a pro 5.0 shifter and all the hydraulics for the car
And the other stuff
Racetronix hotwire kit
Racetronix 255 pump
Bogart rims
28-10.5 m/t slicks
Qa1 coilovers w/ eibach drag spring installed front and rear
Airbags in rear
Bmr tubular k-member
Bmr tubular lower a-arms
Bmr trk-pak torque arm
Bmr sub frame connectors
Wolfe 6-point bolt in cage
Hurst line lock
Synergy 2-step w/ nitrous suspend
Optima red top
Autometer tach w/ shift light
Autometer in cab fuel pressure gauge
Autometer vacuum gauge
Moser 12-bolt rear
5/8 screw in studs
4.56 gears w/ a full spool
3.73 gears w/ eaton posi-unit (not installed)
451 rwhp on motor
599 rwhp on a 150 shot
647 on a 200 shot
those number are thru a 12 bolt that usually costs you about 20 rwhp on a dyno. and 28 inch slicks usually another 5 to 10 rwhp. it is still very streetable with some radials on it.
i will seperate some of the bolt-on stuff to make the price a little cheaper (ie. nitrous, two-step, k-member and a-arms that are not installed yet. i will even keep my rims and tires if you have your own.)
100330 miles
Hardend pushrods
fast 90 intake
nick williams tb
Taylor wires
Tr6 plugs
Long tube headers
Comp cam
23x
23x
60x
61x
112 lsa
6-speed
b&m ripper shifter
hardend syncros
spec 3+ clutch
2002 hydraulics
drill mod
And the other stuff
Racetronix 255 pump
Bogart rims
28-10.5 m/t slicks
Airbags in rear
Hurst line lock
Optima red top
Moser 12-bolt rear
5/8 screw in studs
451 rwhp on motor
647 on a 200 shot
