I just recently picked it up from TX, but I'm gettin a bit more reasonable daily driver. Car drives fine, I've taken it from Memphis to Philadelphia, MS a few times, and it drove back from TX no problem. 136,xxx on the odometer. Couple new parts not currently installed include Accufab oval TB, FRPP aluminum DS, Pypes catback.
Rear end has a little whine to it, but it causes no issues while driving. Car also comes with brand new set of duralast plugs wires, and new pads and rotors all the way around. Front seats are actualy Kirkeys w/ custom covers that match the back seats.
Looking to possibly trade for a clean, IC, Turbo Regal.
mod list:
Paint needs touching up on-
pass door and roof.
CEL stays on due to MAF
Cold AC good heat.
Lakewood rear shocks
UPR solid motor mounts
Bassani ceramic mid length headers
Bassani catted X pipe
Steeda race mufflers
1000 miles on new plugs
255 Walbro fuel pump
C+L mass air meter and inlet tube
ASP underdrive pulleys
AJE K member
Lakewood 90/10 struts
D&D coil overs
UPR caster/ camber plates
Sub frame connectors
Upper/ lower control arms
TKO 600 transmission (good for 600 HP)
Custom clutch
Built rear end 31 spline diff.
FRPP 4.30 gears
Screamin Demon coil packs
98 Cobra wheels 10.5 rears w/ new 315s
-Will
mod list:
pass door and roof.
Cold AC good heat.
AJE K member
D&D coil overs
Custom clutch
FRPP 4.30 gears
-Will
