96 svt drag ready cobra:
basically everything is almost new on this car.
1996 Cobra #657
Black exterior/Tan interior
5% window tint
Fuel system:
Aeromotive A1000 fuel pump NEW
Aeromotive 100 micron filter NEW
Aeromotive fuel pressure regulator NEW
Aeromotive Y block NEW
Aeromotive 99-01 cobra fuel rails NEW
10 gallon aluminum fuel cell NEW
Aeroquip stainless braided fuel line -10 (15ft) NEW
Aeroquip stainless braided fuel line -8 (20ft) NEW
MSD DIS4 ignition NEW
MSD coil pack adapters NEW
MSD 4.6 DOHC plug wires NEW
Ron Davis custom 3 row aluminum radiator
sn95 electric fan
Rearend:
8.8 with tig welded axle tubes (done in jig)
Moser 33 spline axles NEW
Moser 33 spline spool NEW
Moser C-clip eliminators NEW
Ford Racing 4.56 gears NEW
Ford Racing Rear cover/girdle NEW
Steering/Suspension:
UPR Pro-Series front tubular suspension
UPR bump steer kit NEW
UPR/QA1 14" 150# front coilovers NEW
UPR Pro-Series rear suspension w/upgraded hiems NEW
Steeda caster/camber plates NEW
Strange 10 way adj struts and shocks NEW
Welded torque boxes
Fox body rear springs
Flaming River manual rack (Sn95) NEW
Flaming River steering shaft (Sn95) NEW
Aerospace manual brake conversion (Sn95) NEW
TCI line lock/roll control NEW
Summit proportioning valve NEW
UPR quick release quadrent, firewall adjuster, adjustable cable NEW
Chassis:
Wolfe 10 point Chromemoly cage (painted black gloss)
2"x2" through floor frame connectors with kickouts
Stroud window net NEW
Simpson 5 point harness BLACK (2) NEW
Corbeau Forza seats (black)
UPR air bag deletes (painted with saddle dye) NEW
Skinny Kid aluminum rear wing NEW
Weld ProStars 15x3
Moroso D2 26x4.5-15 NEW
Weld ProStars 15x10 (6.5 bs)
M/T 28x12.5 ET Streets
M/T tubes NEW
Taylor aluminum battery box NEW
Flaming River on/off switch NEW
Flaming River switch rod (for on/off through bumper) NEW
Russell stainless braided brake hoses NEW
All new hard brake lines
Repainted engine compartment and inner wheel wells
transmission:
art carr C4
reverse manual valve body
deep sump art carr trans pan
red line billet internals
SFI approved bellhousing
art carr 4500 NL stall (9in billet)
transbrake
1 piece harned shaft
Motor:
04 supercharged engine
ported stage IV eaton blower
electric waterpump
BBK longtube headers
richardson 2.89 pulley
Back up power adder
MMR custom drag ready turbo kit
FRPP coated headers
ceramic coated cold pipes
innovative waste gate
vortech blow off
air to water spearco intercooler
all hot pipes
single 3.5 race exhaust'
i have spend about 40k overall in everything, car,parts,and motor.. this combination will defetnetly be in the 9 sec range or so... all you need is a management system and tune to get this baby to the track...looking for a stage II GN/type...let me know....or something similar in g-body power!!!!!!!!!!!!!!!!!!!!turbo 6...
1996 Cobra #657
5% window tint
Fuel system:
sn95 electric fan
Rearend:
Welded torque boxes
Chassis:
Weld ProStars 15x3
M/T tubes NEW
transmission:
art carr C4
transbrake
Motor:
electric waterpump
Back up power adder
FRPP coated headers
vortech blow off
all hot pipes
![DSC02167.jpg](/proxy.php?image=http%3A%2F%2Fi77.photobucket.com%2Falbums%2Fj79%2Fjusa6%2FDSC02167.jpg&hash=f108bad90bdbfbde5e99ce9a9cf980d5)
