It is a 95 pontiac formula 6.0L LS 400rwhp/389rwtq. Lots of mods, very fast.
Heres my fquick page
fquick.com/garages/Pontia...la/1994/16715/]Garages > gonzo4886's 1995 Pontiac Firebird Formula - FQuick.com[/url]
phone#: 757-256-7942
located in Lakehurst NJ. Willing to drive a couple hundred miles.
-6.0L LQ4 shortblock (2004)6000 miles
-TEA Stage 1.5 5.3L ported heads w/hand finishing
-222/224 .570⦥uro;? cam
-Comp cams 987 springs
-Titanium retainers
-Hooker longtubes w/Y-pipe (no cats)
-Z06 injectors
-Aeromotive adjustable fuel pressure regulator
-255lph Walbro intank fuel pump
-Stage 3 monster clutch
-Tick master cylinder
-2001 T56 tranny w/20k miles
-BIG 4-core custom aluminum radiator
-lowered 1⦥uro;? (BMR springs)
-Metco solid lower control arms
-BMR adjustable panhard bar
-Corsa stainless catback with dual 3⦥uro;? tips & electric cutout b4 muffler
-custom 8pt. chromoly rollbar (NHRA legal) w/rear hoop and bracing
-custom chromoly subframe connectors
-10 bolt rear w/4.10 gears (just rebuilt)
-PA tubular K-frame
-PA tubular lower A-arms
-LS1 front brakes w/new rotors
-Pro 5.0 shifter
-2002 PCM/LS1 engine harness
-Chrome ZR1 wheels: 17x9.5⦥uro;? front, 17x11⦥uro;? rear
-Kumho 712 front tires (80% tread), Nitto drag radials in the rear (new)
-Autometer shift light (small)
-LS1 intake w/stock unported LS1 throttle body!
-Brand new heater core
-Brand new gas tank
-new driver side widow motor
-new brass headlight gears
-tinted windows 15% rear...20% sides...
It is currently making over 400rwhp right now with the STOCK LS1 intake manifold and STOCK UNPORTED throttle body. I am sure a FAST 90/NW 90 would put this thing in the 440rwhp+ range.
The paint is in good condition. The front and rear bumper cover have faded slightly and could use paint.The interior is good condition. No cracks in any plastic, newer carpet out of a 2002 Z28, no tears or anything.
The rollbar/subframes work was all done by Jamie Miller Race Cars in Wallingford, CT. Its all TIG welded chromoly 1 5/8" tubing. The work is outstanding....not some backyard welder/fabricator. The bill on this work alone was almost $3000
The AC is currently the only thing removed from the vehicle. I have all the A/C stuff. I just put on new front calipers, pads, brake booster, master cylinder, rear portioning valve and removed the abs, new brass headlight gears, stage 3 monster clutch, billet flywheel,rear main seal, tick master, and slave.
Things that need to be fixed: the speedo and rpm read half the computer needs to be reprogramed to fix, the rear brakes are need to be replaced in the near future.
Phone Number: 7572567942
-Titanium retainers
-Z06 injectors
-PA tubular K-frame
-Pro 5.0 shifter
-Brand new gas tank
