wtt,street drag car for your turbo car
Tapper
1977 Camaro back half ladder bar car.
(car has gone 9.07 @ 154 mph with a procharged 496 bbc and th400). Car has a
clean title painless wiring all lights work street legal, fiberglass front end
and bumpers 9" ford (456 gears) 31 spline axels full spool ladder bar rear,
draglites
15x12 rears with 29.5x13.5 slicks 8 passes, MT front runners,
, full gauges, 8 gallon fuel cell, 14 point cage and just cert. to 7.50 per
IHRA, MSD6AL, aluminum
Radiator, electric fan, small block headers ,Car weighed 3200 lbs with steel
headed big block and intercooled procharger.
radiator drive shaft (msd 6al Installed)
(NEW)Digital 7 Plus, part # 7520
ENGINE:
Small Block Chevy 383 Short block built by Speed-o-Motive, 4 bolt main, Scat
Crank, Silvolit Flat tops 10:4:1 with 64cc heads, Comp cam 278 e energy 497/501
Balanced, arp bolts, stock rods shot penned.
Short block is assembled and ready to go
Intake Iron/Aluminum Dart 4150 style
Port Matched to Fel Pro
1206 by Doug Herbert Performance With new gaskets
DART ALUMINUM HEADS WITH ROCKERS AND GIRDLES. THE HEADS ARE READY TO GO WITH 215
CC RUNNERS AND HAVE 64 CC CHAMBERS. THE VALVES ARE STAINLESS STEEL AND ARE 2.05
INTAKES AND 1.6 EXHAUSTS. THEY HAVE ROLLER VALVE SPRINGS AND 7/16 ROCKER STUDS
WITH GUIDE PLATES. THE ROCKERS ARE 1.5 AND 1.6 RATIO AND HAVE A STUD GIRDLE
INSTALLED.
Dart valve covers With new gaskets
Camshaft\Pushrods Solid roller custom camshaft and Crane solid roller lifters
Adv. Dur 284/292 Dur @50 250/262 lobe lift 426/431 with 1.5 rocker 639/646 valve
adj, intake 20 exhaust 22 108 lobe separation
TRANS: Neil Chance th400 with trans brakeand converter Refreshed
HOOKER SUPER COMP HEADERS W\ evac Tubes
Flow masters
(NEW) new nos pro shot fogger kit.
(NEW)Aeromotive fuel pump A2000 and reg.
(NEW)holley 950 Hp carb
(NEW) 31' of -10 aromotive fuel line.
via email @ Tapper 1993 @ Cox.net
I have a little over 17k in this car, have paperwork.
Can also throw in a 355 needs a new crank, x rods, your choice of rpm intake or perfomer, or torker style, 882 heads, 650 sec or dbl pumper for the right deal.
Would like a mod car or really slick stocker. NO Junk NO rust bucket NO over sees scammers ect.
