XFI 2.0 is now available
HighPSI
Moderator
Staff member
The new software has been released today. I have forwarded all the requests that were emailed to me to FAST.
I will be getting that serial # to you via text tomorrow if that is okay?
Besides the reflash of your ECU you will also need the 2.0 software
Which will be supplied with the 2.0 flash update.
The 2.0 flash is not compatible with your 1.340 or older software.
Without the software update your XFI WILL NOT communicate
Another very important step that should be mentioned is once all updated
you will need to paste in the proper injector/battery offset file
which you will find in the new software update.
You wil need to go to FILE- PASTE FROM FILE- (look in injector offset folder)
find your injector and click OK.
This table may also need to be fine tuned per application
You can contact me if you need any help with this
so does this mean you can get a 2.0 case. i just got a new xfi last thursday it came in a ols case/ looks used
It will have to be sent back in to have the case swapped out.
are the cases ready yet? I can not get anyone at fast to give me a answer. This is the case I got with a BRAND NEW UNIT just taken out of fast box thursday in the wraper
If you purchased it from us, give Holly a call and we will take care of it
Well if I were you I'd be calling motorstate up to have them take care of that for you. If that was supposed to be a new unit.:eek:
So what order do i do things...reflash ecu then update c-com or update c-com first then flash ecu...
-Dan
I think I have sent all the 2.0 option files out that I have received. Please PM me if you emailed me your serial# and did not receive the file
So how long does it take to get the file from Fast? Holly told me to order directly from Fast. I ordered yesterday around noon and still do not have an email. Just curious.
Cal, I bought internal logging from you when I first bought my XFI from you. Will that have to be reinstalled? I think I have long lost the email with the option file.
Tom
it took about hour and half to get mine from fast. i called after hour and he said it could take up to 24 hours. but should come in 1-6 hours and to call back if not.
Tom
should still be enabled mine was/is:smile:
-Dan
