I'm using an XFI and 50lb high Z injectors. For cold starts, I have to crank up the after start fuel curve off the top of the chart to keep it running after it fires, or it stalls out. The car runs fine, there does not appear to be any vacume leaks and the O2 readings are reasonable. Is anyone else using the 50lb high Z's and what does your after start fuel curve look like?
