Otto,
Thanks for the information. When I first started it up it did not have the FCS code. Now every time I start it up the check engine light comes on and the code comes up. I will try to disconnect the battery to get it to clear.
Jeff
Otto,
Jeff
No need Jeff,Just go online with the ECU.go to "VIEW"
then "System configuration"then"fault detection"
and unclick hte box for "FCS"
It wont come back on,The XFI will not hold codes once hte key is turned off unless you have not fixed the problem.
Unhooking the battery will do nothing.
